Error message help
hailst8
3-Newcomer
Error message help
I am having some issues with a solve block. I have had this issue before, but I forgot what I did to fix it. I get an error message that says "No solution was found. Try changing the guess value of TOL or CTOL." Can someone help me? The issue is at the bottom of the code.
RichardJ
(To:hailst8)
You didn't attach the referenced file functionoptimizer.xmcd
hailst8
3-Newcomer
(To:RichardJ)
It is attached now
