You can down load sheets (MC 15 and Prime 3) of the Euler Method of ODEs solution.
One question - how simple have arguments of the augment function - as in rkfixed (see the plot please)?
Must be one form for this arguments for one ODE and 2, 3, 4... ODES.
Thanks, But it not work by one ODE
Thanks, Richard
But I prefer this variant (for the book)
ЗЫ. Я балдею от единиц измерения при решении ODE в Prime!
Valery Ochkov wrote:
Thanks, Richard
Привет Валерий ,
The problem with the results is that the nesting is not consistent with the output from the standard rkfixed ODE. Although it might look notationally simpler and more consistent, it presents problems with using the data later on ... the graph notation is quite complex to do what it does. You might be better off using a column operator for the Y data, spicing things up with a mix of column operator for Y and row operator for X, or even using just the column operator to retain the notational consistency.
One other minor observation is that you need to index i from 2..n+1 to get the same number of points as rkfixed.
Stuart
Thanks!
I think this is a final variant (for one equation and for a system):
Не за что.
Не за что.
Есть за что!
I missed this until now, but if you want the last point to be at x.e, then delta should be equal to (x.e-x.b)/(n-1).
and rkadapt
Nice ![]()
Richard Jackson wrote:
Nice
THANKS!
But now after your quick reply I cannot correct |a-5| to |x-5| ![]()
And do you know symbolical solution?
You've to to zoom out a bit to get the plots to look like that ...
I say to my students thet thay must check solutions from Internet.
But myself do not do it ![]()
конечно! само собой разумеется!
"Do as I say, not as I do" is a Universal Maxim - ask my children!
Stuart
Stuart
Now USA try to say to Russia - Do as I say, not as I do ![]()
From my facebook
