Exponents and WRITEPRN
BillDumkeHome
I need to create a comma delimited text file with two vectors in scientific notation. How do I extract exponents from a scientific ntation? Or is there a better way of doing this?
Attached file is in Mathcad 11 format. But I do have Mathcad 14 available as well.
Thanks, Bill
Just write the file. WRITEPRN uses the E notation as necessary.
__________________
� � � � Tom Gutman
On 8/3/2009 1:48:41 PM, BillDumke wrote:
== I need to create a comma delimited text file with two vectors in scientific notation. How do I extract exponents from a scientific ntation? Or is there a better way of doing this?
== Attached file is in Mathcad 11 format. But I do have Mathcad 14 available as well.
On the presumption that you need all numbers in scientific notation, here's one way. It uses a component to do the conversion and file deletion. (I already had them so reuse was a quick option - it should be possible to rewrite num2sci in Mathcad).
Stuart
Thanks, Stuart.
That looks like your solution will work fine.
Bill
