Hello All,
I'm trying to convert excel sheet formula into Mathcad.
Example, I want to extract P/N No. from the excel table.
Stud dia and Load is the input variables.
Load value should be more than the Min load value and near to maximum load in case of multiple variables.
If load value is not available in the Column 2 and 3 then same steps will be carried for parallel min and max load (column 4 & 5).
Can you please help me on this problem.
Have changed the excel file to a later version necessary to read the data from the Excel file rather than use the Excel component.
Each stud diameter seems to have a L, M, and H versions. I would expect the load capable of being carried increases from L to M to H.
The data in the Excel file seems to be inconsistent with this so needs to be checked.
Sorted the data on the max load per stud column to get them in increasing order.
I assume max load varies depending on how many studs in a group. In the excel column for parallel max load is twice stud load? Should this actually vary with number of studs?
Enclosed is sheet that chooses studs based on load to show you how to do it.
Cheers
Terry
Hello Terry,
Excel data values are 3rd party value and there is some inconsistency in the actual file as well.
Can you please send Mathcad file in the 7.00 or earlier version?
Pavan
Hi Paven,
Cannot promise but will see if I can.
Cheers
Terry
Thank you Terry.
Hi Paven,
Prime cannot be saved back to an earlier version. Have tried a trick that sometimes works but has not done so in this instance. Cannot give you a version 7 file.
It does not take long to type the values in:
Cheers
Terry
