Factor a simbolic expression
ptc-6727461
Hi. I have the folowing expression in mathcad:
and i want'it to look like this:
How do i do this in MathCad?
Thank you
(To:ptc-6727461)
Use the symbolic coammnd "factor".
You can't have a superscript as part of the name. Guess it would also be too easy to mix it up with exponantiation anyway.
5 REPLIES 5
(To:ptc-6727461)
How did you insert in the expression that "factor" command?
Thank you
(To:ptc-6727461)
Either use the Symbolic Keyword Toolbar
or type the keyboard shortcut Strg & Shift & . and type in factor manually.
Then right klick the expression and chose "Hide keywords" and chose "View Evaluation As" - "Equal Sign".
And if i have the following expression:
and i want it to look like this:
where alpha1..3 = a1..3 and omega1..3=F1..3 and
How do i do it in MathCad?
Thank you very much sir.
(To:ptc-6727461)
How should Mathcad know?
But you sure could define your expression that way.
Maybe you have luck using "explicit,ALL" if you define and use A first.
