File conversion .xmcd to .mcdx(Prime6.0)
ssato
Hello everyone
I installed MATHCAD15 and PRIME6.0.
But file converter has the following message.
The message is
 " The conversion process could not be started."
Please advise me.
(To:Werner_E)
I stumbled over an old support case.
Maybe it helps if you try the suggestions given there.
https://www.ptc.com/en/support/article/cs103001
pdf print attached
8 REPLIES 8
VladimirN
24-Ruby II
(To:ssato)
What service release of Mathcad 15 did you install?
ssato
(To:VladimirN)
Hello  VladimiruN san
I installed Mathcad 15.0 (M050 [MC15_M050_20171129]).
Is the order of installation with PRIME 6.0 related?
(To:ssato)
Thats OK, its the current version.
Not that I would be aware of. As a single user you normally you would install Prime first just because the product number you need to get a license file will only work with Prime and not with Mathcad. So when you later install Mathcad you can point it to the license file you got when you installed Prime. If your company runs a license server this does not apply.
When installing Prime 6 (in parallel to Prime 5) I did't reinstall Mathcad 15 and Primes converter works OK. So this shows that the installation order does not matter.
Of course (the documentation states it, too) you lose the ability to do the conversion with older versions of Prime you may still have installed. Conversion will only work with the newest Prime you have installed.
(To:Werner_E)
pdf print attached
ssato
(To:Werner_E)
こんにちは、Werner_Eさん
あなたの応答は正しいです。
私の問題は解決しました。
ありがとう。
(To:ssato)
お手伝いできてとても嬉しいです。
Googleおじさんがそれを正しく翻訳してくれたらと思います;-)
ssato
(To:Werner_E)
Hello Werner_E san
Your(?) Japanese is very good.
Thanks again.
(To:ssato)
@ssato wrote:
Hello Werner_E san
Thanks again.
Its sure not my Japanese, its Japanese thanks to Google translate 😉
