File corrupted !
klajditp
File corrupted !
Guys i enjoy using mathcad, its fast and easy . But i have this big problem now. My file is corrupted at some line. I did a lot of work and i cant lose this file. Anyoune can help me ? The important part of the file is just the first half . Please guys help me .
LucMeekes
(To:klajditp)
Region "373" was corrupt. It contained (which may help you find which equation it dealt with):
        <region region-id="373" left="294" top="3333" width="138" height="12.75" align-x="425.25" align-y="3342" show-border="false" show-highlight="false" is-protected="true" z-order="0" background-color="inherit" tag="">
            <math optimize="false" disable-calc="false">
                <ml:provenance expr-id="1" xmlns:ml="http://schemas.mathsoft.com/math30">
                    <originRef doc-id="C47AAC3D-B68D-4C73-9DEB-06E74C8C7652" version-id="05A2161F-F156-4CB5-9D32-CEE2855508CF" branch-id="00000000-0000-0000-0000-000000000000" revision-num="2" is-modified="true" region-id="0" href="C:\Users\User_8\Desktop\7 Страниц.xmcd" xmlns="http://schemas.mathsoft.com/provenance10">
                        <hash>de97812e0ce4922462f402b0b98e2056</hash>
                    </originRef>
                    <parentRef doc-id="C47AAC3D-B68D-4C73-9DEB-06E74C8C7652" version-id="05A2161F-F156-4CB5-9D32-CEE2855508CF" branch-id="00000000-0000-0000-0000-000000000000" revision-num="2" is-modified="true" region-id="0" href="C:\Users\User_8\Desktop\7 Страниц.xmcd" xmlns="http://schemas.mathsoft.com/provenance10">
                    </parentRef>
                    <comment xmlns="http://schemas.mathsoft.com/provenance10"/>
                    <originComment xmlns="http://schemas.mathsoft.com/provenance10"/>
                    <contentHash xmlns="http://schemas.mathsoft.com/provenance10">25915d37be9747c117f56845be489686</contentHash>
                    <ml:apply>
                        <ml:mult style="auto-select"/>
                        <ml:apply>
                            <ml:apply>
                                <ml:neg/>
                                <ml:id xml:space="preserve">изгибающий</ml:id>
                            </ml:apply>
                            <ml:apply>
                                <ml:parens>
                                    <ml:sequence>
                                        <ml:id xml:space="preserve">момент</ml:id>
                                        <ml:apply>
                                            <ml:placeholder/>
                                        </ml:apply>
                                    </ml:sequence>
                                </ml:parens>
                                <ml:id xml:space="preserve">Нм</ml:id>
                            </ml:apply>
                        </ml:apply>
                        <ml:placeholder/>
                    </ml:apply>
                </ml:provenance>
            </math>
            <rendering item-idref="97">
                <element-image-map>
                    <box left="1.5" top="0.75" width="136.5" height="11.25" expr-idref="1" xmlns="http://schemas.mathsoft.com/worksheet30"/>
                </element-image-map>
            </rendering>
        </region>
After removing it, the attached file results.
Please check if it works.
7 REPLIES 7
LucMeekes
(To:klajditp)
                    </originRef>
                    </parentRef>
                    <ml:apply>
                        <ml:apply>
                            <ml:apply>
                                <ml:neg/>
                            </ml:apply>
                            <ml:apply>
                                <ml:parens>
                                    <ml:sequence>
                                        <ml:apply>
                                            <ml:placeholder/>
                                        </ml:apply>
                                    </ml:sequence>
                                </ml:parens>
                            </ml:apply>
                        </ml:apply>
                        <ml:placeholder/>
                    </ml:apply>
                </ml:provenance>
            </math>
                <element-image-map>
            </rendering>
        </region>
You can open that file in a text editor.  You may be able to find and fix the error
I hope that's what I did...
klajditp
(To:LucMeekes)
Man i dont know how to thank you . everytjing fine now. thnx a lot seriously !
He sent me this by PM, and I fixed it for him. Very annoying that we duplicated the work! I even marked in the file where the region (which of course I deleted) was. I haven't heard anything back from him though.
LucMeekes
(To:RichardJ)
And he posted his corrupt file in another thread where MJG fixed it for him.
Is that triplication?
klajditp
(To:LucMeekes)
Sorry for all the mess i caused.  Never going to happen again. I thank you and the other guys that took my problem seriously and answered so fast.
