Guys i enjoy using mathcad, its fast and easy . But i have this big problem now. My file is corrupted at some line. I did a lot of work and i cant lose this file. Anyoune can help me ? The important part of the file is just the first half . Please guys help me .
Region "373" was corrupt. It contained (which may help you find which equation it dealt with):
<region region-id="373" left="294" top="3333" width="138" height="12.75" align-x="425.25" align-y="3342" show-border="false" show-highlight="false" is-protected="true" z-order="0" background-color="inherit" tag="">
<math optimize="false" disable-calc="false">
<ml:provenance expr-id="1" xmlns:ml="http://schemas.mathsoft.com/math30">
<originRef doc-id="C47AAC3D-B68D-4C73-9DEB-06E74C8C7652" version-id="05A2161F-F156-4CB5-9D32-CEE2855508CF" branch-id="00000000-0000-0000-0000-000000000000" revision-num="2" is-modified="true" region-id="0" href="C:\Users\User_8\Desktop\7 Страниц.xmcd" xmlns="http://schemas.mathsoft.com/provenance10">
<hash>de97812e0ce4922462f402b0b98e2056</hash>
</originRef>
<parentRef doc-id="C47AAC3D-B68D-4C73-9DEB-06E74C8C7652" version-id="05A2161F-F156-4CB5-9D32-CEE2855508CF" branch-id="00000000-0000-0000-0000-000000000000" revision-num="2" is-modified="true" region-id="0" href="C:\Users\User_8\Desktop\7 Страниц.xmcd" xmlns="http://schemas.mathsoft.com/provenance10">
</parentRef>
<comment xmlns="http://schemas.mathsoft.com/provenance10"/>
<originComment xmlns="http://schemas.mathsoft.com/provenance10"/>
<contentHash xmlns="http://schemas.mathsoft.com/provenance10">25915d37be9747c117f56845be489686</contentHash>
<ml:apply>
<ml:mult style="auto-select"/>
<ml:apply>
<ml:apply>
<ml:neg/>
<ml:id xml:space="preserve">изгибающий</ml:id>
</ml:apply>
<ml:apply>
<ml:parens>
<ml:sequence>
<ml:id xml:space="preserve">момент</ml:id>
<ml:apply>
<ml:placeholder/>
</ml:apply>
</ml:sequence>
</ml:parens>
<ml:id xml:space="preserve">Нм</ml:id>
</ml:apply>
</ml:apply>
<ml:placeholder/>
</ml:apply>
</ml:provenance>
</math>
<rendering item-idref="97">
<element-image-map>
<box left="1.5" top="0.75" width="136.5" height="11.25" expr-idref="1" xmlns="http://schemas.mathsoft.com/worksheet30"/>
</element-image-map>
</rendering>
</region>
After removing it, the attached file results.
Please check if it works.
</originRef>
</parentRef>
<ml:apply>
<ml:apply>
<ml:apply>
<ml:neg/>
</ml:apply>
<ml:apply>
<ml:parens>
<ml:sequence>
<ml:apply>
<ml:placeholder/>
</ml:apply>
</ml:sequence>
</ml:parens>
</ml:apply>
</ml:apply>
<ml:placeholder/>
</ml:apply>
</ml:provenance>
</math>
<element-image-map>
</rendering>
</region>
You can open that file in a text editor. You may be able to find and fix the error
I hope that's what I did...
He sent me this by PM, and I fixed it for him. Very annoying that we duplicated the work! I even marked in the file where the region (which of course I deleted) was. I haven't heard anything back from him though.
Sorry for all the mess i caused. Never going to happen again. I thank you and the other guys that took my problem seriously and answered so fast.
