Foor Loop
ppal
18-Opal
Foor Loop
Hi all.
Why am I seeing all the extra rows  of Zeros?
I just want to see 4 to 8
Thanks for the help.
Indexes into matrices start at zero
9 REPLIES 9
What version are you using?
You need to include the file.
Attached now
Attached
(To:ppal)
@ppal wrote:
Attached
No, still not.
Whats going on?
Do you try to attach a worksheet or a picture?
Work sheet. When I do a picture it says 20 000 words exceeded.
(To:ppal)
You can't simply copy and paste a picture here, you have to use the "Photos" icon to embed a picture in a post or you may add it like you did with the worksheet.
BTW, I would rather use
(To:ppal)
We see neither zeros nor 4's or 8's!
Obviously you forgot to add a picture, or, preferably, your worksheet.
My crystal ball thinks that the reason for your problem is that you use a vector or matrix which was already defined before with a larger size or that for some reason an element with higher index was unintentionally assigned.
Not necessarily, as the picture below shows, but it sure would make more sense to leave the default ORIGIN=0 (or rather set it to 1, but sure not 4)
