For loop output to matrix
- February 2, 2012
- 1 reply
- 26697 views
I am a beginner with programming in Mathcad. I am having trouble understanding how to use FOR Loops to dump results to a matrix from which I can extract values to plot in a graph. I wish to solve a non-linear equation and evaluate this function for a range of values and then graph the results in the form of a Bifurcation Diagram. The non-linear equation becomes chaotic at certain input force values.
I have constructed a Runge Kutta 4th order function to integrate the equation and develop the displacement and velocity time waveforms - no problem. As a first step I want to evaluate the equation for a range of forces and store the velocity (Y2) versus time (Y0) waveforms in a matrix. As a second stage I want to sample the velocity waveform after it has stabilised (after say 100 cycles) at periopdic intervals to see if the velocity amplitude remains stable or whether a chaotic behaviour occurs.
The attached Mathcad file has the integration front end and my attempt at a nested FOR loop to index the force amplitude and store the velocity (Y2) values in a matrix. The matrix output only seems to store the last iteration. I would appreciate if someone could get me over this first hurdle to evaluate all velocity waveforms for the range of forces 'A".
Extracting data to a new matrix after every N1 data points would be the next step and then plotting this data as aBifurcation Diagram.
Any assiatnce would be appreciated.
Cheers
Ross
