I just posted the same question last week and got several good examples returned. I suppose you can find them by clicking my avatar and investigating my posts.
May be this help you:
I fear it doesn't. The point was to deal with a system of three equations which has no unique solution automatically. That is: the point of intersection is plotted if it exists, otherwise it is suppressed.
Not an easy task considering that 3d graphs are not parameter driven. Not even the axis limit can be variables.
If its still of interest after nearly three year. As you wrote you can make the point show up at (0/0/0) in case of a not unique solution you could put it out of the way completely? Of course this would mean that you have to chose the acis limits manually.
