Can someone please help me with an issue, in the attached file, i would like to write the complete range of data outputs Re(Zpq(f)) and Im(Zpq(f) to an excel file, in column A and B. How can i achieve it?
Thank you
Look up the help info on excel component, starting with "To Insert an Excel Component" and follow the steps. Make sure your installation complies with the requirements.
Unfortunately I cannot help you step by step, because I'm limited to Prime Express.
Presently your list of complex values is a range, rather than a vector.
You may need to convert that to a vector by doing, e.g.
See also the attchment.
Thank you very much. I was able to acheive the task.
If it works like Prime 3.0, Then
Thank you very much for the guideline.
Next video tutorial "Using the Excel Component" will be useful for you: Tutorial: Using the Excel Component
Thank you for the link, it was really helpful.
You're welcome.
