Higher Order Ordinary Differential Equation
ptc-2119345
Hello all, Can Mathcad 12 numerically solve 2nd order ODEs directly or does the 2nd order ODE need to broken up into a system of 2 first order ODEs? Thanks Matt
While the actual solution is calculated on a system of first order ODEs, MC can do the conversion automatically by using the ODESolve function.
