I downloaded a zip file from the PTC community from the following URL.
·Finding the Shear Force and Bending Moment Along a... - PTC Community
After downloading and unzipping the file, I have a file extension of .mcdx (relations_between_distributed_load_shear_force_and_bending_moment.mcdx). I tried to open this file in MathCAD however; the file fails to open. How can I get this file to open? I am using PTC MathCAD 15. Should the extension be .xmcd?
Apperently the .mcdx files are for MathCAD Prime. How can I convert MathCAD Prime files (.mcdx) into MathCAD 15 files (.xmcd). I have tried simply changing the file extention but that did not work.
Thomas Henkel
PTC has decided that there should be no way back (Prime itself is backstep enough).
So you can't convert Prime sheets (mcdx) in real Mathcad format (xmcd or xmcdz).
You even cannot convert Prime 3.1 sheets to Prime 3.0 format (and of course Prime 3.0 cannot read 3.1 sheets).
... or can wait for a maple or mathematica package ...
But what do you mean?
But what you can do is open the file with Prime 3.1 express, which you can install for free.
Mind though, there may be errors in that sheet.
I don't trust the expression for MBC(x) that appears on page 6...
I have to correct. The expression for MBC(x) is OK.
And retype all into mcad15 for use it or modify something? Document is 8 page length, taked frome Roark's formulas, which have ... a lot of more pages.
Please find in attachment this worksheet in PDF and XPS file formats.
