How do I create a String object in scripting?
CarlDreher
I'm retrieving a list of File objects and want to manipulate the file name. However, whenever I try to do any String manipulations with myFile.Name, I get a VBScript error that it isn't a String object. So that lead me to start looking at Strings and getting absolutely nowhere.
For example, Mathcad won't let me do any of the following:
1. Set str = New String("foo") (All of these generates an "expected end of statement" error. Huh?)
Dim str = String("foo")
Dim str = new String("foo")
2. str = "foobar"
index = str.lastIndexOf("foo") (Complains "object required", which I presume means it doesn't think str is a String object.)
3. str = "foobar"
index = LastIndexOf(str, "foo") (Error is "type mismatch")
This is driving me nuts! How do I create a String object, especially from the file.Name method?
Errors are:
1. "String" don't exist as an object (actually the word is a function), are a data type. So you can assign with Set or New. The error "expected end of statement" is because can't use Dim with assignation in vbscript.
2 & 3. "foo" isn't an object nor str.
I think that what you want is the funciton Len(str) which return the string length.
VBScript is a very small subset of the basic language. You can try to find in your computer the file "script56.chm" or try in microsoft web to download it.
Regards. Alvaro.
RichardJ
(To:CarlDreher)
VBScript or JScript? You can write a scripted component in either, bt not a mixture of the two.
The code you have in 2 and 3 is JScript. In VB a string is a variable subtype, not an object.
I have many examples of how to do this kind of stuff. What exactly are you trying to do?
OK, I eventually found what I was looking for thanks to the link to the script56.chm.
As pointed out, VBScript doesn't handle strings as proper String objects. (Obviously, VBScript was written a long time ago!)
So, to manipulate the file name (obtained from a proper File object), I must do this:
Dim myString
myString = myFileObject.Name
Then I can use various string functions that exist separately, such as
myIndex = InStr(myString, "*.txt")
to get the index of the *.txt suffix.
RichardJ
(To:CarlDreher)
Yes, VBscript is a little old.
If you tell me what you are trying to achieve though, I may have something already written that could save you a lot of work.
Thanks, but I've got it done. Once I realized I had to use the various functions that work on string-like variables, it was easy.
