How to Fix the Guess Value
rjaison
I am using the solve block Find function to find the two unknown from two given equation
If my guess value is not close enough to the correct value it give a error message "The variable is undefined"
Please refer the PDF attached.
I have a curious question why to define the range of the unknown just above the Find function if function can not use them to find the correct values.
May be I am thinking wrong !
I have attached the Math CAD file when opened please input the same as referred to the attached "INPUT DATA" so to have the similar results.
Is there a way to instruct the Math CAD Find function to do the increment between the given range instead of guess value as I am finding it difficult
Because for every problem I have to enter the close enough guess value to get the right results.
BR,
J.Randeep
RichardJ
(To:rjaison)
Right click on "find", and check "AutoSelect" (which is the default, so at some point you disabled this).
7 REPLIES 7
I don't get the error message! It works (don't know if it gets the correct result - but I get no error message).
Alan
Hi
That is strange I tried for example input one of the guess value as 0.001
please see the attached Math CAD file.
The correct results as attached "Correct Results" which is at the bottom of the program
P:S please remember to input the data as the attached "INPUT DATA"
J.Randeep
RichardJ
(To:rjaison)
Hi
Thanks it did solve the issue to Find
you where instructing that I should disable the Auto Select at some point.
Will it have any effect if I keep them selected all the time.
Now I have the issue with Maximize & Function I don't know why, May be I have syntax wrong
Please see the attached
J.Randeep
Hi Again
I just Modified the Guess Value Range for Maximum and minimum function (for the "4_EN 1992_Stress Vs Strain Rec Parabolic_Max Min.xmcd")
See the attached
Hi Richard Jackson and Every one
I have opened a new thread for my second question about Maximum and Minimum Function
"Maximum & Minimum Function of Two Equation"
J.Randeep
RichardJ
(To:rjaison)
Possibly, but I would only recommend that in special cases. Leaving it on autoselect is the best option most of the time. Only force it to a specific algorithm if there's a reason to do so.
