How to assign the solution of a equation to a vector?
坤荀
Mathcad can solve aequation and give the solution directly. But I hope the values of the solution to be assigned to a veriable or a vector, how I should do?
坤荀
(To:坤荀)
I fixed it now.
Just put the vector and colon before the solution expression.
(To:坤荀)
Mark you lasr answer as "correct answer" to signal, that there is no need for answering.
