How to change and append matrix items of a globaly defined matrix via program?
pklemm-2
6-Contributor
I want to create a global result table with fixed columns. From anywhere behind the definition of that table I will insert new result lines or modify existing rows. For modification, the first column is a key column, so that the match-Function could give back the row number:
My problem is, that the ResultTable will not be changed. Also not if I write
ResultTable:=AddResult("key123","Cap1","that's a nice result",4.5)
Yes, I know that inside a program the assignments are local. How to make global?
Thank for help!
StuartBruff
(To:pklemm-2)
You have to pass ResultTable as an argument to AdddResult.
Stuart
6 REPLIES 6
StuartBruff
(To:pklemm-2)
Stuart
pklemm-2
6-Contributor
(To:StuartBruff)
Thank you, Stuart
yes that works in that way:
ResultTable:=AddResult(ResultTable,other arguments)
but is there no possibility to change global variables directly?
(To:pklemm-2)
No. The first time you use ResultTable on the LHS of an assignment in your program you automatically create a local variable with that very name and all subsequent calculations are done using this local variable. So you can't change a worksheet variable from within a program the way you tried to do.
In Mathcad 15 there may be a way of doing it using scripted component - not sure about that and not available in Prime anyway.
R
RichardJ
(To:Werner_E)
That can indeed be done in MC15. However, as you say, it's not a solution for Prime.
StuartBruff
(To:pklemm-2)
Peter Klemm wrote:
Thank you, Stuart
Well, possibly there is a way ... it works in Mathcad 15 but it's an undocumented feature.  I think it still works in Prime 3.1, but I'm not sure and don't have Prime available to check.   It makes use of a "feature" (aka "bug" ... but maybe not) that allows a function to create a closure around an array, which provides a means for updating the array.  It needs careful handling and the worksheet should be written and then calculated as a whole to make sure that all evaluations are carried out in the intended order.
Here's an example based around a Fibonacci function ...
Stuart
pklemm-2
6-Contributor
(To:StuartBruff)
Thanks again.
I will try it.
