With reference to topic
when I double click a Mathcad file, the default language will be launched. I would have to launch Mathcad first with the special shortcut (that includes the command line option "/culture:en-US", for English) and then open the file.
Is there another way?
2 possible solutions:
1.] look into Windows registry and modify key defining MP startup command ... maybe following key is the right one (I am not 100% sure)
2.] uninstall MP and installed it again using English as the only one language
Thank you for the suggested solutions.
The Windows Registry change worked fine.
[HKEY_CLASSES_ROOT\MathcadPrime.exe\shell\Open\command]
was changed to:
"C:\Program Files\PTC\Mathcad Prime 11.0.0.0\MathcadPrime.exe" "%1" "/culture:en-US"
The 2nd option did not work: During installation there was no option to select languages.
Hello @ElEngMSch,
It looks like you have a response from our community champion. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
