How to convert XMCD file into MCDX format?
dkothia
The file is from Mathsoft MathCad, but I want to run it in the new PTC MathCad what is the solution please answer ASAP. And are the two software same?
202 REPLIES 202
@Werner_E wrote:
You sure have noticed, that the results you show differ from the original ones.
Ziel nichts bewegen alle!
Hello, it there any chance these files could be converted from XMCD files to mcdx files?
Many thanks
Which version of Mathcad Prime are you using?
Hi
I'm using Mathcad Prime 4.0
These are as converted. I have done nothing to clean them up. The files with .xml extensions are the conversion logs. Unfortunately, files rarely convert perfectly, and that is the case for these files. There are some formatting problems, but more importantly all three worksheets used the gradient operator, which does not exist (like many other things) in Prime.So the worksheets do not actually work.
Thanks for taking the time to do this Richard, I appreciate that.
Do you know of an equivalent function for the gradient function in Prime 4.0?
Many thanks.
Calculate the derivatives for each variable independently:
Hi!
I have a .xmcd file that I need to convert to a .mcdx file. I'm having trouble installing MathCad 15 on my computer but I have a MathCad Prime 4.0. Enyone willing to help with the conversion?
Marco
Converted to 3.0, you should be able to read.
I need info from an XMCD file I made in 2013.  I ran the utility "PTC Mathcad Prime 4.0 XMCD, MCD Converter" but the conversion failed because version 15 was not installed.  I navigated to the PTC download page for Mathcad and found v15 not available.  How can I install v15 in order to make the file conversion?
If you can post the file (may have to zip it) someone here will convert.
(I have been unable to find a download link either)
Please find in attachment converted worksheets for Mathcad Prime 3.1 version.
Thanks Vladimir, I really appreciate that!
I would like to have MCDX format for two files. I am attaching the files with this. Please help me as soon as possible.
VladimirN
(To:Nisarg)
Please find it in attachment (for Mathcad Prime 3.1 version).
Hi there,
I also have a couple files that I would appreciate having someone convert to MCDX for me. Thanks so much.
SJ
Fred_Kohlhepp
23-Emerald I
(To:sethaj)
Which version of Prime do you need?
If I convert (now) you'll get Prime 4.0; if you're running an older version you still won't be able to read it.
Better to get Mathcad 15 installed--it's free with Prime and required to convert.  And 15 can do things that Prime still can't
I need Prime 4.0. I would just download Mathcad 15, but I'd need to get IT involved and go through red tape, so this is easier and appreciated.
Thanks.
Fred_Kohlhepp
23-Emerald I
(To:sethaj)
attached (I hope)
Hi Fred,
Unfortunately it looks like you re-uploaded the XMCD instead of the MCDX...
Fred_Kohlhepp
23-Emerald I
(To:sethaj)
Sorry!
Need more coffee!
Could you please convert the attached file to .mcdx format?
Thank you
Antonio Arthay
AdriCreu
(To:aarthay)
Here it is.
VladimirN
(To:AdriCreu)
Don't forget to specify for which Mathcad Prime version the file is converted.
AdriCreu
(To:VladimirN)
Mathcad Prime 4.0
ProfJ
2-Explorer
(To:AdriCreu)
Hi Vladimir,
Any chance you could convert the following to Mathcad Prime 4.0?
J
Fred_Kohlhepp
23-Emerald I
(To:ProfJ)
converted, not opened
and deleted by request
Thanks very much.
Hi, can you convert this file to mathcad prime 3.0?
Im in a hurry, thanks!
