How to convert XMCD file into MCDX format?
AM_10161393
3-Newcomer
The file is from Mathsoft MathCad, but I want to run it in the new PTC MathCad what is the solution please answer ASAP.
Enclosed is converted file to Prime 7.
There is a problem with rkfixed function used in the Prime worksheet.
LucMeekes
(To:AM_10161393)
Which version of 'the new Mathcad' Prime do you have/want to use.
If it is version 7, you should be able to convert it with the built-in converter.
If it's an older version 1...6, you need to have Mathcad 15 installed in parallel, on the same computer, to do the conversion....
thanks alot man for helping me out
love you mate
