How to create a 3d surface/contour plot in prime 2.0
ptc-4699986
Hello All,
I have 3 vector for X, Y, Z but I am unable to create a 3d surface plot or contour plot of this in mathcad prime 2.0
I have read somewhere that is is not possible anymore but maybe there is a way to do it.
many thanks for the help.
One way attached.
Alan
11 REPLIES 11
One way attached.
Alan
many thanks for your reply, it works great.
I have altered the sheet a little te include my real data and use a contour plot i.s.o 3d surface.
Somehow the colormap is wrong, do you know how to fix that too?
(To:ptc-4699986)
You data ranges from -300 to -40, so you should change the colormap accordingly
See attached
thanks for the help, but in you file the colormap is also wrong.
I have values in the z matrix that are higher than let say -50 and they should be orange according to the colormap. But they are not.
(To:ptc-4699986)
I see what you mean, but this are only about 6 values on the outer right edge. Obviously not making a plane region for Mathcad to shade.
Maybe you get a better looking plot using a spline interpolation of your surface.
(To:ptc-4699986)
After playing around with the sheet a while I agree, that the behaviour of the colormapping is at least not reasonable to me, too. I wouldn't call it a bug yet as maybe its just because of the coarse grid - we only have a 4*25 data table.
Find attached a version which uses a spline interpolated function from your data table - think it looks better.
many thanks for the interpolation hint.
haha we where working on it at the same time.
I see you also came up with a solution.
I added a function which uses Bicubic2D to create the new interpolated surface and it seems to work.
or is it not meant to be used for this?
(To:ptc-4699986)
Bicubic2D seems to be exactly meant for this. From the description it looks like it does pretty much the same as my routine, but with a prebuilt command. You may like to compare two plots done with my routine and bicubic2D - I haven't done it but I guess there would be no difference.
Bicubic2D is new in Prime and I was not aware of its existence - I'm a Mathcad 15 user and I plan to stay with that version as long as possible, as Prime is not really a full fledged alternative at the time being. But sometimes one is able to discover an advantage.
Bicubic2D does seem to do the same but with a linear interpolation.
I checked it by changing you routine from cspline into lspline and the results where identical.
Many thanks again for the help
(To:ptc-4699986)
Good to know, but why is that method called biCUBIC then?
I don't know why they call it BiCubic2D.
this is what they say in the help file:
"The Bicubic2D function is equivalent to using lspline in two dimensions, with no restrictions on the number of rows and columns of the input values. To obtain a value for a new point, Bicubic2D interpolates down each column of the Z matrix, creating a new row. It then interpolates across the new row. "
