How to customize your own units in mathcad calculations
richardm55
7-Bedrock
I use Mathcad 2015 and when I calculate thermal resistance in K/W I get output in completely different complicated units using meters and seconds. How to force Mathcad to give me result with desired units?
LucMeekes
(To:richardm55)
Please tell us more about this Mathcad 2015, or did you mean Mathcad 15...?
When you evaluate an expression, there's a placeholder for units behind the result value. You can fill in the K/W and the other stuff will disappear if unit of the result actually is K/W.
You may want to check what the setting for units is that you use with your worksheet (Tools->Worksheet Options -> Unit system). It can be set to SI, MKS, US, CGS or none if I'm not mistaken.
I do a reference on one Cloud Mathcad sheet and have for example Russian units
I can add in this file your custom units!
-MFra-
(To:richardm55)
You may be interested in this topic "Design of a small residential heating system" that you find doing a search in "search all content", there are many custom units of measure.
I think we must do it manual each time
