Hi all
Please, see the attchd.file.
There is a graph where I would like to represent parameters x and y related to z.
I have no idea how to define the x and y axis.
Does anybody have an idea how to do that? Thx
Yes it is necessary to establish a nested vector of the x, y, and z coordinates like this
A contour plot is the best way to visualize the resulting nested M matrix
Cheers
Terry
HI ValeryOchkov
could you share the .mcdx file ,thx
How about creating an interpolation function? See attached sheet.
As your data matrix is square its not clear if x would relate to the columns or to the rows.
In the attached sheet I assume that x would relate to the rows, and y to the columns.
If it should be the other way round (as Terry assumed), you simply have to exchange X and Y when calling linterp_2D().
