Hi!
I want to simulate the accuracy of the Euler-Polygonzugverfahren with MathCad.
The allgorithm is a numerical approximation which the accuracy depends on the variable "n" with a programmed recursive function of the velocity. (I'm not that familiar with programing)
Now my problem is: How can i display this function for n=6,10,20 timesteps in one diagram to visualize the accuracy?
Thanks in advance.
Can't open your file. (Still using Prime 3.0)
Possibility of a picture?
Thanks Fred,
exactly this is what i'm searching for.
