How to do this using genvals/genvecs commands in Mathcad Prime 9.0
ReedzBeedz
3-Newcomer
In the file attached (and photos below) I am trying to do the routine of finding ϕ using eigenvector and eigenvalue functions to do the same thing I did manually with A1. A2, A3 and the other matrices. Is this possible and if so can someone please help me out in doing so? Thank you!
(To:ReedzBeedz)
Actually "genvecs" generates the necessary vectors. But on contrary to "eigenvec" there is no "genvec" which would return an eigenvector associated with a certain eigenvalue.
And "genvecs" returns the vectors in the same order as the values in "genvals" and also differently scaled.
Scaling could easily be fixed but I don't know if the order after sorted eigenvals could be automated.
But of course we could automate what you did manually
(To:ReedzBeedz)
(To:Werner_E)
Here is an approach using only "genvals" and "genvecs" which seems to do the job as desired:
As a generic utility function its ORIGIN-aware
Prime 9 sheet attached
Thank you very much for your help this is exactly what I needed!
