Hi.
Example. I have this formula:
V = S/t
V - speed
S - distance
t - time
I don't know values, but i want to find formula for find S.
How can i do it with mathcad?
Can mathcad give me result like this:
S -> V*t
Requires symbolic evaluation
Sorry, but i cant put
after V. Only
can, but result is zero.
Mathcad has a lot of different equal signs!
In this case, for entering an equation, you'll have to use the boolean equal sign.
You can get it from the menu ribbon (Math - Operators - Comparison - Equal To) or using a keyboard short (on my keyboard its "Ctrl +", on yours it may be "Ctrl =").
The boolean equal sign looks bolder than the one you use for evaluation (=) or the one used for assignments (:=).
Thanks! 🙂
