How to insert values previously obtained into a table and trace the graph
zaki_rhm
8-Gravel
How to insert values previously obtained into a table (as shown in the last of the attached file) without manually typing them. and trace the graph pV.
From help documentation
"A table is a region where you define data sets."
Tables are an input not an output function.
Your input table entered manually creates three vectors:- points, pressure, and volume
Not all the data is defined so pressure and volume cannot be plotted yet.
You cannot plot pressure and volume with each point marked by the character in "points"
Cheers
Terry
