How to read value of a matrix into a loop
Bartz87
I want to make a program that will test the value of h above, h is a matrix containing (1, 4, 11, 7), starting from top to bottom (1 then 4, 11, to 7), if h > 10, then stop the loop, when h is still less than 10, then the value of s will add to 1 and stop only when the condition is met. then extract the value of s into "section". What is possibly wrong or missing in my program.
Pls see the attach mathcad file. Thank you for your help
6 REPLIES 6
Have a look at the attached.
Remember ORIGIN = 0.
Mike
Thank you very Mr. Armstrong
That really help....now I can program what I have in mind
You know I'm new to MCAD but i'm really interested in learning more
Thank you again for your help
No problem at all. I have shown how this can be achieved using a for loop and Alan has shown the while loop method. A good starting point would be to learn the two different methods and understand the differences between them.
Read through the forum and ask questions when your stuck - basically teach yourself and learn from others that's the best way to learn.
Mike
Another possibility.
Alan
Hi Mr Stevens,
I've used your idea of the while loop in my program, but I have a problem. Pls see the attach MCAD file.
Neptali Barte wrote:
Hi Mr Stevens,
You need to include Fe etc inside the while loop.
Alan
