Contour plot can be done using the graph option in mathcad. But, i need that in an image format which can be opened outisde mathcad atmosphere. Is it possible? if it is means, could you explain me?
If you save it in HTML format the graphs are saved as images.
Or Ctrl+A - Point and copy this plot in ClipBord
... or save the data to Excel and use Excel to do a contour plot (replace Excel with whatever other app springs to mind that does contour plots)
Stuart
