How to solve a symbolic equation for vibration system
sfan
Hi, friends.
Is there a way to solve the symbolic solution for a vibration system in mathcad?
Such as f(t)=0, and the solution should be in the form of Asin(wt+a)+Bcos(wt+a)
Thank you in advance!
Looking forward to your help!
Shawn
LucMeekes
(To:LucMeekes)
Ah, you wanted the general, symbolic solution. Well here goes:
12 REPLIES 12
RichardJ
(To:sfan)
Mathcad cannot solve differential equations symbolically.
sfan
(To:RichardJ)
Hi, Richard,
What if I define the values for these parameters?
say:
m=10, mb=5, E=29000, I=500, L=15.
Is it possible to find the function of v(t)?
Thank you
RichardJ
(To:sfan)
Not using the symbolic processor, no. I don't know if it can be solved using Laplace transforms, it's not something I have any experience with. LucMeekes seems to be kind of a whiz at that though, so maybe he can give an opinion (or, even better, a solution!)
sfan
(To:RichardJ)
Yeah, I just visit Luc's post, it is fabulous.
Laplace transform works great!
Thank you very much!
MikeArmstrong
(To:sfan)
Please post your solution here to help others.
Mike
Hi, Mike
The attachment is how I used the method of Laplace Transform to solve the equation.
Hope that could help.
Best
Shawn
LucMeekes
(To:sfan)
Hi Shawn,
Good to know that my work is inspiring.
You give:
as the "governing equation", I interpret that as 'the solution'.
For this v(t) it follows that
Much different from the initial conditions that you state:
which are again different from the ones that you actually use:
You should get:
The mistake is where you substitute the expression for c into v(t). you're effectively using v(t) - 1 rather than v(t), so you end up with a 'governing equation' for v(t) - 1.
sfan
(To:LucMeekes)
Thank you for your correcting.
My work still needs improving.
Your example is really inspiring and you are the best!
BTW, May I ask the reason that you collect the inverse laplace with sin(2t), cos(2t) and exp(t) in this step:
Is it because you found the term on the left side can be traced back to the basic laplace transform like laplace(sinat)= a^2/(s^2+a^2)?
Or collect the inverse laplace with sin(2t), cos(2t) and exp(t) is a universal method in this step?
Thank you for your help!
Shawn
LucMeekes
(To:sfan)
It's certainly not universal (contrary to the formula I use to solve linear differential equations of any order with constant coefficients).
The collection is a remnant of a solution for another problem.
In general the result of the invlaplace is a complicated and 'messy' expression. I usually inspect it to see what are usefull elements to collect. After judiciously choosing the parts for collection the expression often becomes more understandable.
In your case there was a single sine, not with 2t as argument, so the collection didn't do anything.
sfan
(To:LucMeekes)
Got ya.
I think it might be better off for me to go review some of the basics of Laplace Transform
before utilize it in Mathcad.
Thank you, man!
LucMeekes
(To:LucMeekes)
sfan
(To:LucMeekes)
You are my hero, Savvy!
