Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
I only know of one way. It's called "addition with line break operator". The Keystroke is [Ctrl][Enter]. Essentially it breaks the equation at an "addition area". If you are subtracting, just add and make scalar value negative. In Version 14 help, look up "Addition Operators"
No knowledge can be certain if it is not based upon mathematics or upon some other knowledge which is itself based upon the mathematical sciences. -- Leonardo da Vinci
Thanks, but I'm trying to find the maximum value using the max(..) operation. I won't be able to use your suggestion since I'm only using commas and not +/- signs.
Put all the values into a vector, which can be vertical (or even two or more vectors if necessary) and pass max() vector arguments rather than scalar arguments.
