Alright so I have a data set that when graphed produces 2 peaks or are two distributions..
i want to split the graph in two...
for example if the data set is
set= [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25]
and i want to spit it into two vectors.. say till element 13.. so that the split looks like this
set1 = [1,2,3,4,5,6,7,8,9,10,11,12,13]
and
set2 = [14,15,16,17,18,19,20,21,22,23,24,25]
will a while loop work for this? or is there a better method
i tried with while loop but the syntax i used just sums up till element 13. 😕
update:
k so just thinking out loud here but shouldnt the following just simply split the vector:
set[0;set[d
where d is set to the mid point (13th value)
i tried that but it only gives me the value at 0.. that is set[0
thanks a lot mike ![]()
ill check it out now
Oh, by the way it can be done using a while loop, but can be donw alot easier.
Mike
Thank you ![]()
For your hopeful amusement if not edification ...
I've added a couple of new 'timer' functions Counter1 and Counter2 that allow the user to specify how long to keep repeating a function and return the number of iterations. This is in contrast to Timer1 and Timer2 which allow the user the specify the number of iterations and return the time it took.
Stuart
Very nice as usual.
Surprising how slow the submatrix function is.
Mike
Hi Mike,
I suppose 'slow' is a relative term. It's comparable to iteration for small data sets, but for the larger ones it's about 25 times faster on my machine.
Stuart
