How to use "on error" in my function.
mzarrabi
Hi everybody. I have attached a picture of my function. Does anyone know how to find a way that the while loop goes to the next loop whenever there is an error in the D_M function?  My current way of coding does not work and I cannot find the reason.
MJG
18-Opal
18-Opal
(To:mzarrabi)
I believe the following two options would give you what you want:
6 REPLIES 6
RichardJ
(To:mzarrabi)
The format for "on error" is "x  on error y". It evaluates y, and if that gives an error, it returns x instead. That is not what you have. Note that you cannot just type "on error" into a placeholder. You must enter it from the programming toolbar.
mzarrabi
(To:RichardJ)
Dear Richard,
Thank you for your response. Now, I understand what was the problem. I modified it a little bit. Now there is another problem.  When yj equals to "x.calculations" the function stops as I want, but it does not show "x.calculation" as the last answer.
Best,
(To:mzarrabi)
use
return "x.calculation"
instead of
"x.calculation"
break
Note, that "return" is a command liek "if" or "on error" and you have to chose it from the toolbar and can't simply type it in.
mzarrabi
(To:Werner_E)
you are right, but if I use "return", the function gives me the last value of y. In fact, I'd like to see previous values of y also.
MJG
18-Opal
18-Opal
(To:mzarrabi)
mzarrabi
(To:MJG)
Thank you very much MjG. It works well now.
