IDE - Add/Remove Space usage?
The Mathcad Prime Documentation tab contains two dropdowns for adding and removing space, respectively. The Add Space button allows the addition of a single line or a page. The Remove Space button allows the deletion of a single line or all empty space down to the next region (if any).
I frequently add extra pages to allow plenty of leeway for adding new regions in between existing ones. I always find it a bit of a nuisance having to press the Add/Remove buttons twice to tidy up the worksheet afterwards.
I don't think I've ever used the single line option for either adding or removing spaces. It is almost trivially easy to carry out these tasks using the Enter or Delete/Backspace keys, switching to Draft Mode if necessary to ensure the correct cursor position (which is almost certainly necessary to use the single-line button options, anyway).
So, I was wondering if anybody makes use of the single line options, or would miss them terribly if the drop-downs were replaced by buttons for just Add Page and Remove Empty Space?
Stuart
