Nowadays while waiting for Mathcad completing a simulation, I have to listen to the CPU-fan. After finishing it reduces its RPM and I can go and see the results.
It would be nice to have a progress bar indicating some kinde of progress- this would be possible if one work sheet is calculated several times with small changes only...
Egg timer?
Mike
1) Set-up sounds to play at different points in the program
2) Use the "debugger window" and the trace() function at key points in the worksheet to print out progress.
I get the feeling that this might upset the my colleagues in the office. ![]()
Mike
Hi Mike,
In this case you can use headphones. ![]()
P.S. I'm glad that you are back in the community.
debugging would slow down the calculation, I find no sound routine.
Unfortunately Mathcad won't play sound on its own.
Find attached a sheet with three components, one which plays a selectable number of beeps and two which play wav-files.
The routines were stolen from here over the time 😉
EDIT: replaced the file for an updated/corrected one
