If loop with a range variable
ksk_10594232
Hi
How do I program an if-loop with a range variable, and not a scalar? Is that possible?
I found a solution to get around the problem. Thanks anyways!
11 REPLIES 11
The "if" statement is a branch, not a loop!
Its unclear to me what you mean and how this would have to do with a range variable.
Maybe you can give a couple of examples of what you are looking for.
If you are looking for multiple branching like the "switch" statement in C - Prime does not provide a comparable statement.
But depending on the specific problem its often possible to find a simpler solution compared to a cascade of if's and elseif's.
I have attached an example which I hope will clearify my question 🙂
And what kind of data structure do you expect as the output?
You have to be aware that ranges are not vectors! Ranges should only be used on three occasions:
To index the elements of a vector or matrix
In a for-loop inside a program
As abscissa values when you plot a function
In all other cases you should use vectors.
Maybe this is what you are looking for:
Prime 9 file attached
Here is solution that does not use programmed if statements suitable for Express version of Prime.
Cheers
Terry
If you are looking for a version for Express, it would be easier to use the if-function instead of the programmed if-statement once x.test is defined as a vector and not a range.
Or you do completely without any "if" and use the "min" function, which is also available in Prime Express
Using functions has various advantages over manipulating vectors throughout (which is a way of working many are used from using a spreadsheet program).
Thanks ! 🙂
How can I use the same approach for an else/if statement as shown in the attached file?
You again turn the calculation into a function and call it vectorized with a vector (not a range!) as argument.
Or are you looking for a function which also works in Prime Express where programming is not available?
The you would use nested if-functions, similar to what you have to do in any spreadsheet program like Calc ode Excel - but this tends to look cluttered and messy:
I understand, but I don't know how to write the above calculation into a function.
My bad, I noticed that to wrote above 😄 Thank you
