Import data from excel to mathcad
NA_11204287
8-Gravel
Hi all, is there any ways to import the data from excel into the Mathcad table?
Data in excel table
Data in Mathcad Table
Thank you for your help! *i'm using MathCad Prime 10.0.0.0
StuartBruff
(To:Werner_E)
@Werner_E wrote:
A Prime table can only be typed in manually.
Not quite.  I played and found that you can paste Excel data directly into a worksheet, and Mathcad inserts it as a Table.  Here's an example that I just created ...
To Import Data from Excel
Of course, I would have saved myself some time and effort if I'd watched your link first, as this method is explained therein! 🙂
Still, nice to know that it worked as I intuitively hoped it would.
Stuart
Edit to add: I couldn't find a way to link a table to Excel, though.  Still, as you say, there is little need to do so.
7 REPLIES 7
(To:NA_11204287)
A Prime table can only be typed in manually. Its just for input, not for display of already existing data.
But a Prime table is simply a collection of vectors.
You could use the function READEXCEL to read in the data from the Excel sheet
StuartBruff
(To:Werner_E)
Stuart
wonderful! this solution works on me. many thanks!
No worries.  Werner had pointed to the solution in his message, as well.
Cheers,
Stuart
(To:StuartBruff)
and he wasn't even aware of that 😄
(To:StuartBruff)
OK, admittedly thats not 'typing' but still is what I had in mind when I wrote "manually".
You cannot import data from Excel via a command and display them as a table but of course copy & paste still is much less tedious  and failure prone than retyping  😉
I remember quite some threads here where the feature to display already existing vectors and/or matrices in that kind of table format was requested but up to now a table still is intended for input only.
StuartBruff
(To:Werner_E)
Hey, I pressed Ctrl-V, Werner.  What more do I have to do to *type* it in?  😁
Stuart
