On 1/24/2010 6:49:25 AM, rmix22 wrote:
>BTW - off topic: How do you
>manage to show an inline image
>in the middle of your text and
>not at the end?
_______________________________
In the body of the text and starting in a new line, you insert the coding. If you want just the image and no message at all, you must type some whatever something like ........... Always leave an empty line at the top and bottom of the code.
Gif01 is one of my gigantic collection of all the images I have attached in text. It is an Irfanview for easy retrieval. They are all in reduced color for saving memory. Having included the code in the text above, when you click on "Post", it sends the panel browser where you click the icon "Mona" and browse for where the image is in your PC. Once in there, double click on that image name, then click on "Upload now".
After your image name you type .gif> and close the code, the dot must be from the letter keyboard, it does not accept the numerical dot. As long as the image you are inserting is an image, the code will accept ... it accepts *,bmp, *jpg but not only *.gif.
Try it back, send us "dog" from your Mathcad install directory .
jmG
