I'm trying to insert an Excel component in Mathcad Prime 7.0.0.0, and I keep getting an error that Excel is busy. But Excel is not running. I have checked the task manager, and Excel is not open.
Even in the list of background processes, Excel is not running.
Read Excel seems to work fine.
Unfortunately this is a very common error in Prime from the very beginning and it seems still not be fixed.
If you search this forum for "Excel busy" you'll find a lot of complaints about this very same bug and also a couple of workarounds you may give a try.
Maybe some of the answers here help, otherwise i would suggest opening a support case at PTC support:
I did search "Insert Excel error", but I guess I didn't go far enough. Much appreciated. Thanks Werner.
Hi
For me the only thing to do to solve this infamous Excel component - was to rapair Microsoft 365 !
After that no problem - Mathcad Prime 8.
Owe
