Integrate a function between varying limits and return the result as a vector
AATaylor
I would like to integrate a function between a certain number of pairs of limits. The number of pairs is set by a variable, n.th. I'd then like to return the result as an n.th x 1 vector. Could anyone help please?
Please see attached.
Many thanks and kind regards
(To:Werner_E)
And if you want it to be done by a more generic function, you could do it that way:
Worksheet attached.
(To:AATaylor)
You may use a range variable to do the job
(To:Werner_E)
Worksheet attached.
Even better! Thanks!
Brilliant, that's exactly what I was looking for, thanks. Can;t believe I didn't think of that myself...
