Hi All,
I'm trying to calculate the properties of a weld. As part of this i need to integrate to the shape area to find area, second moment of area, etc.
One of the piece wise function's gives an error once i go over a certain number on the depth.
The function works fine when calculating properties about the x axis but not the Yaxis. Please find the problematic function attached.
Any idea's how to fix this?
Here is A turned into a function of b
As we can see, the algorithm used by Mathcad ever so often misses the two peaks for certain end values.
I wrote a quick (and inefficient) integral function just to show what it should look like
But I won't recommend using this function as it is.
To improve the results of Mathcads integrals you may decrease the value of TOL or chose a different integration method. But neither helps in your case.
I guess you should follow the advice given in the help which says
So instead of
you would use
to get the correct result.
Which error do you encounter?
I can't see any error message in your sheet.
EDIT: Ah, I see! You were not talking about a Mathcad error but rather about wrong results. The numeric integration of your step function has a of of strange results at various values of b. You can see it clearer if you turn A into a function of b and plot it against b.
Not sure how to fix this other than calculating the area without an integral (which is easy in case of your function but may be a problem with others).
So instead of
you would use
I have had similar problems when working with point loads on beams.
Things that I have found to sometimes work are:
1) Using the adaptive RungeKutta integration option
2) Convert the square pulse into a cosine pulse with the same area as the pulse.
See attached
I have mathcad 15, so I can't open your file. Can you put up a screenshot?
It's been a while since I have done much calculus.
Hi, there.
Attached is a pdf - which Prime 8 is good at producing.
If you need any more help just ask.
@CW_10436044 wrote:
....One of the piece wise function's gives an error once i go over a certain number on the depth...
1. Please show a screenshot of this error.
2. What version of the program are you using?
