Interaction between 2 MathCAD files ???
ptc-4283043
I am trying to establish communication between 2 Mathcad files cause i would like to Mathcad file 1 to retrieve few data from MathCAD file 2.
I found that Mathcad is able to communicate with other kind of documents (like xls,word, etc) .
Any help in this direction is appreciate.
Arun
Arunachalam Nagarajan wrote:
Thanks for your quick reply.
MathCAD file 1:
E = A + B+C+D
D = 4
C=
E =
MathCAD file 2 :
C= A+B
A= 2
B =3
In the above example i would Match CAD file 1 to retrive the data from MathCAD file 2 for the variable " C" .
Arun
If you insert file 2 as a reference into file 1, then everything you have defined in file 2 will be available in file 1. Everything! Including A = 2 and B = 3.
Which looks like it may be a problem for you. You could write C into a text file in file 2 and read it in file 1. Short of a scripted component I don't see another way.
6 REPLIES 6
Arun
Try please Insert/Reference command.
Or do you need some others, more!?
There are many ways to interact worksheets. How about posting an example for further assistance.
Mike
MathCAD file 1:
E = A + B+C+D
D = 4
C=
E =
MathCAD file 2 :
C= A+B
A= 2
B =3
Arun
MathCAD file 1:
E = A + B+C+D
D = 4
C=
E =
MathCAD file 2 :
C= A+B
A= 2
B =3
Arun
As Fred as stated you could reference a Mathcad worksheet inside another, but personally I would write it to a text file or excel worksheet and call it up in the other Mathcad sheet.
Mike
RichardJ
(To:ptc-4283043)
The controller and dummy worksheets I posted here might be useful to you:
http://communities.ptc.com/message/164310#164310
