Interchange more than two colums between two arrays
rcallisaya
Hi, I also know how to interchange more than two columns between two arrays, as shown in the attached file.
Thanks.
(To:Werner_E)
For whatever it may be worth here is a slightly improved version with the benefit that the same columns could be used multiple times:
MC15 sheet attached
(To:rcallisaya)
May like that (error check is only implemented rudimentary):
Mathcad15 sheet attached
(To:Werner_E)
MC15 sheet attached
I really appreciate  the solution , thanks
