Hi, I also know how to interchange more than two columns between two arrays, as shown in the attached file.
Thanks.
For whatever it may be worth here is a slightly improved version with the benefit that the same columns could be used multiple times:
MC15 sheet attached
May like that (error check is only implemented rudimentary):
Mathcad15 sheet attached
MC15 sheet attached
I really appreciate the solution , thanks
