Interpolation data
mctraila
Interpolation data
Hi everyone.
I have a little problem with an interpollation data. When i start to use cspline the program give return error "The elements in this vector must be in ascending order."
Mathcad 14.
P.S. Sorry for bad english.
(To:mctraila)
Looks like you posted an empty worksheet !?
When using spline interpolations, the values in the first vector ("x-values") must be in ascending order to make the interpolation work. As you get the error message you describe they obviously aren't all in that order.
(To:mctraila)
mctraila
(To:Werner_E)
The worksheet start with second page. Values in the vector is ascending.
(To:mctraila)
Tricky 😉
The problem in your sheet is, that you obviously are not aware, that by default the first index number of a vector is 0, not 1.
You created your vectors using a range variable j starting at 1. But the vectors you created that way also have an element with index 0 (by default has the value  0) and as the first value in your vector i is 0, too, the first two elements are both 0 and thats not strictly ascending.
Two possible solutions:
1) Define j as j:=0 .. 11
or
2) Write ORIGIN:=1 at the top of your sheet (alternatively you may set the value of the system variable ORIGIN via the menu -> Tools -> Worksheet Options -> Built-In Variables -> Array Origin(ORIGIN)->1).
For the screenshot below I used option 2
mctraila
(To:Werner_E)
Thank you
