Dear all,
I have a (example) table like this:
| 1 | 2 | 3 | 4
5 | 11| 12 | 13 | 14
6 | 21| 22 | 23 | 24
Where the top row is A (values 1 to 4), the left column (values 5 and 6) is B and the field values (11 to 24) are Y.
Now I want to find the value Y belonging to A=2,5 and B=5,5 using linear interpolation.
Currently I have split the table into multiple small tables, one for each column, and then first create a new table for A=2,5 and then interpolate in that table to find the result for B=5,5.
This however takes a lot if programming to create the table for A=2,5 (as we have to first indicate which two tables to use based on the value of A).
Is there a direct way of doing this?
Thanks in advance for your replies.
Thanks for your reply.
Imo my method is easier than yours. 🙂
Conclusion will be I guess there is no direct way of doing this.
Please attach your worksheet then.
{You may have to ZIP it first, there's a bug on this forum that often causes a failure to attach a worksheet.
To zip, in Windows explorer select the worksheet file, then with the right-mous button select 'Send to'=> 'compressed (zipped) folder' the resulting .zip file can be attached.}
Thats quite possible but you haven't shown your method yet.
Mine is a (couple of) utility routine(s) -> write once, use many 😉
You may simply copy the collapsed area in a worksheet (or reference a worksheet with this and other utility routines) and use it as any built-in command.
There is a "direct" way using built-in commands, but it will only work with a square data matrix.
