Is it possible to disable area in MC15?
ifomenko
To debug module (reference file) I need to have an area with input variables in the beginning of the module.
I want to enable them in case of debuging and disable after.
Is it possible?
Does Prime have such possibility?
9 REPLIES 9
(To:ifomenko)
Unfortunately neither Mathcad nor Prime offer that feature, You can only disable single regions, but not all regions in an area at once.
But when the area is collapsed, you can move it (e.g. to another sheet or to the bottom of your sheet) out of the way, which might be an option for you.
ifomenko
(To:Werner_E)
Thank you, but fortunately it`s possible to disable several regions at once.
(To:ifomenko)
Yes, it depends on the size of the area, the number of regions in that area, if its more comfortable to select them all and disable them or if its more convenient to simply move the collapsed area out of the way to effectively "disable" all regions inside.
I close an aria and move it in the other sheet. Then return back!
Yes, thats exactly what I already suggested in my first anser here!
Sorri, Ai no Inglish veri plokho and du not rid yor message about it 😞
Thats bad, what a pity
May be so
May be so
Thats not disabling a whole area at once, but yes, thats exactly what ifimenko meant when he wrote "fortunately it`s possible to disable several regions at once."
