Issues saving as PDF file in Prime 9.0
ED_9745095
2-Explorer
Hello all,
Trying to figure out why certain pages come out blank when I print to pdf or try to save as pdf for the file linked below.   Shows up on the screen fine.   Same issue if I try saving as an xps file too.
Thanks in advance
Eduardo
(To:ED_9745095)
I can't duplicate the problem you describe. When I open your sheet (I can't let it recalculate because of the missing Excel files) and save it as pdf, I get a pdf which looks quite OK. I attach it here.
But I remember that other user as well reported about problems with the built-in pdf export here in the forum and the workaround usually was to use a different pdf printer like AdobePDF, Microsoft Print to PDF, CutePDF or others. So you may give it a try with a third party pdf printer.
EDIT: Haven't seen the other replies when I started mine.
As you write that you used "Microsoft Print to PDF" I also tried and the resulting pdf was quite OK, too. is was a lot larger, So maybe the built-in pdf export does not include all fonts used - just a guess.
6 REPLIES 6
Two things are needed.
Can the Excel data file be uploaded or the Prime file is just a sea of red errors?
What PDF printer is in use there are a number of options that all print to pdf?
Cheers
Terry
Hello Terry,
Sorry about that.  I have attached the excel file which is used to read in input and to write out the output from the associated MathCAD file.  I had to resave as a macro free spreadsheet in order to upload.  I have also attached the corresponding pdf file which has a blank page 7 which I can't figure out why it doesn't print out correctly.   We are using "Microsoft Print to PDF" driver.
Eduardo
ppal
(To:ED_9745095)
Hi
Seems to save fine . Perhaps its a Page setting issue?
(To:ED_9745095)
Thanks for checking on this.   Seems your pdf indicates it is an issue with the PDF driver.  Going to check with our IT department to see if they can provide a workaround for me.
Thank you all for taking the time to provide input.
Eduardo
PDF995 Suite has a pdf printer that is free or very cheap to avoid a web browser add.  Used by over 20 million worldwide including industry big hitters.
Prints your file perfectly..  Recommend it to your IT department.
Cheers
Terry
