Hi
I am currently converting files from 15 to Prime which must of it have been successful.
I have an issue with this equation below:
Here are the input:
I can plot the data easily, but I cannot get the intersection point which im trying to with the root function.
It works in mathcad 15:
I found a solution for it by myself, by adding a guess before the root function.
You should attach the worksheet(s). That 'll help us much better to help you.
